How do you Remove Inside Door Handle?
I am replacing the side panels in my 1974 Arrow and everything is self explanatory except the panel on the door. I have to remove the door handle to remove the panel and it is not obvious on how to remove it. Any suggestions?
Brad Goodbread
Okeechobee, FL KOBE
I think your '74 is probably different than my '77 Arrow. Can you post a picture?
It may have the Jesus Clip behind the panel.
Brad Goodbread
Okeechobee, FL KOBE
There is a Black plastic insert in the handle that has a slit to insert a Flat Head Screw Driver and lightly pry it out, then there is 1 Phillips Screw that holds it in. Less than 1 minute operation.
The Platic Trim Piece around the door handle broke when pulled it off. Be Very Careful.
Brad Goodbread
Okeechobee, FL KOBE
Now I have to find this piece on Ebay, etc...
Brad Goodbread
Okeechobee, FL KOBE
That piece is a Volkswagen part.
Found 2 options on Ebay. The Chrome one is just like the one on my plane.
Brad Goodbread
Okeechobee, FL KOBE
The one for $31.95 is actually metal and not plastic like your original.
Great work, Gents! :)
That was a very useful discussion. Parts sourcing amazing.
wow nice job everyone, thank you!
Digital Product Manager
Piper Owner Society
I actually bought both the Chrome Metal and the Black Plastic Handles. I used the Chrime Metal one. It did not come with the black plastic insert trim piece, so used my old one.
Brad Goodbread
Okeechobee, FL KOBE
C33-S01476 - (113837239B - 113-837-239B) - GERMAN QUALITY FROM C&C U.K. - CHROME RELEASE HANDLE SURROUNDS - STANDARD BEETLE 67-77 / GHIA 65-70 / BUS 74-79 / TYPE-3 62-73 - SOLD PAIR
https://www2.cip1.com/c33-s01476/C16-311-247-BK - (311-837-247 311837247) - FINGER GUARD INSERT - TRIM PLATES BLACK - BEETLE 67-79 / GHIA 64-74 / BUS 68-79 / TYPE-3 62-74 - SOLD PAIR
https://www2.cip1.com/c16-311-247-bk/VWC-113-837-020-BCH - INNER DOOR RELEASE LEVER - RIGHT - CHROME LEVER WITH METAL BRACKET - BEETLE 67-79 / GHIA 64-74 / TYPE-3 67-71
https://www2.cip1.com/vwc-113-837-020-bch/The VW part numbers are on the backs of the parts themselves
Dan
Dan
1975 PA-28R-200
