Just a note, I have seen discussions that say perhaps any PAR36 lamp could be considered a suitable replacement for the GE4509 which is not a PMA product (i.e. STC not required). Similarly, the 89 lamp is an automotive instrument bulb with no PMA that piper uses in their aircraft. The 89 lamp is getting harder to find but cross reference data from lamp manufacturers will point you to other "suitable replacements". I don't see a problem using an alternate part with equivalent fit and function and doubt you would be called out on it.
I finally found time to install the LED lamps in my Arrow Instrument panel. I was going to post some pictures but the site isn't cooperating. Anyone know any tricks to get the pictures to upload?
OK, more than one way to skin a cat lets see if this works
Now can anyone fill me in on how to get to the lamps at the bottom of the panel. I can't figure out how to remove the plastic overlays or the gear handle.
Tim
The plastic gear handle screws on/off of the metal shaft. It's possible that there may be a set screw as well though my 1978 PA28R-201T has none. For the rest of the lower panel, I've had to first remove the "eyebrow" pieces from the lower edge of the panel (pilot and co-pilot sides). The screws holding both the eyebrow and the lower panel point up and are hidden behind round covers about 1/2 inch diameter on the eyebrows. Also remove the landing light lenses and bulbs.
Wouldn't the light bulbs be considered a "standard part", manufactured to a government OR industry standard and thus be permissible ??
