I presume you are missing the original POH that matches the serial number of your plane. If that's true, this is easy because you only have one choice: contact Piper directly. Have your plane's serial number and a credit card handy when you call them. Be prepared to spend around $300 (your price may vary).
Once you have the serial-matching POH, get a current weight & balance and put that paperwork in your POH.
1981 DAKOTA POH
Hi David;
Does anyone know if Piper will supply an official digital version now that the FAA allows digital versions in place of paper?
Hi Swankaj;
A phone call to Piper would confirm. If you find out, post it here. Thx!
According to the piper website, there may be ePOH options.
Technical Publications Notification Service | Piper Aircraft
https://www.piper.com/technical-publicationsI put an electronic copy of my maintenance manual, parts manual, and POH in Foreflight but keep the printed version in the luggage area.
