Hello From N738C
Hi All, some what new to this. We recently acquired a Piper 6XTC as they are now known. Very nice airplane, now getting a face lift to all new Avidyne avionic, including two IFD440s to replace older Garmin 430s. Not really happy with Avidyne's customer service as the replacement of the PFD is taking 4 weeks, but that's the way it goes.
We enjoy flying on simple two day trips with friends or the occasional 3-4 day ones to go to Napa, Texas or other destination spots. Be happy for to hear any suggestions. We are based in Glendale AZ,
Cheers,
Dale & Val
  • Look forward to seeing a new panel welcome aboard. Carl
  • Dave & Val;
    Welcome!
    Congrats on the airplane purchase. Looking forward to seeing the new instruments. Post pics!
  • Well all upgrades completed Thursday, 8/22. PFD updated at factory, ...two new IFD 440s, new transponder for ADS-B in & out. Also MFD update to Integra 8.2.2. All total about $60 grand. Only thing not new is S-tec 55x autopilot, which was quite sloppy when tracking a nav, but good in hdg mode and all vertical modes worked.
    We hoped updating PFD would take care of tracking issue. WRONG. On first flight after update I put the autopilot on in HDG and v/s-alt and reached for my gopro to record it and before I could even turn it on, plane rolled 30 degrees left, the 30 degrees right. I dropped the camera clicked a/p off and returned to straight and level.
    WELL I thought, what did I do wrong? (FYI I am retired AAL captain with lots of GA experience). I recycled A/P master switch and then reengaged and same result. Tried again the next day and same thing.
    It's will be back in the shop tomorrow, but wondering if anyone might have some ideas of what is going on. VERY FRUSTRATING
    We hoped updating PFD would take care of tracking issue. WRONG. On first flight after update I put the autopilot on in HDG and v/s-alt and reached for my gopro to record it and before I could even turn GP on, plane rolled 30 degrees left, then 30 degrees right. Sort of like unusual attitudes on a check ride. I dropped the camera clicked a/p off and returned to straight and level.
    WELL I thought, what did I do wrong? (FYI I am retired AAL captain with lots of GA experience). I recycled A/P master switch and then reengaged and got the same result. Tried again the next day and same thing.
    It will be back in the shop tomorrow, but wondering if anyone might have some ideas of what is going on. VERY FRUSTRATING
  • Hi Pa32-n738c,
    Wow, after investing in such an extensive avionics upgrade and finding the Autopilot still not functioning properly is certainly a disappointment! You did the right thing by taking it back to the shop for analysis. There are so many variables.
    It sounds like the Autopilot was not working well before the upgrade. The shop will probably verify the GPS steering signals (GPSS) are all being sent and received properly. If so, the problem may be in the controller itself. Some shops have loaner units or may be able to secure one to confirm the issue is with the controller and not in the aircraft or other avionics systems. Please keep us posted on what you find! It will certainly help others faced with similar problems.
    • Michael Jay Jones (MikeJJ)
  • Hi Mike,
    Just wanted to let you know that we fixed the issue for about $250 labor. We took the plane to Chandler Avionics here is the Phoenix area and the tech figured out that our turn and bank indicator (which is behind the panel) was shorting out and sending bad signals.
    Plane is flying great now.
    Thanks again,
    Dale
  • Sweet! Carl
  • Now that you are in the Muggle world with the rest of us GA pilots, get ready for creative routing on instrument plans in order to accommodate the heavy iron 😉
    The one I love is a 90* intercept to join an approach between IF/IAF and FAF. This also puts me slightly above the glide slope. Not going to name names, but so far there is one ATC sector that loves to give me that intercept even when I am in zero visibility. One of these days I might balk and demand the whole approach, including the procedure turn outside the IA/IAF, just to protest a bit and clog the system. 🤪
  • Jim "Doc Griff" Griffin
